Kiggly girdle a good idea for street applications?
Wanagofast
108
3
Nov 12, 2013
Newman lake, Washington
As of right now im getting a final parts list together and i've heard girdles help the bottom end strengths. I was wondering is it good idea or eve necessary for a 300-350whp (goal) build? :confused:
For such a conservative build its not needed. It will make the block near bullet proof but the torque you are gonna make isn't going to require it.
It's a good idea if you have a lot money to throw at the build. because its not just bolt it. It requires block clearancing and possibly align hone of the mains.
I know the Kiggly's are like 120$ and i was wanting to use arp on the bottom end, so wouldn't that require an Align hone as well?
I'm doing the 6 bolt swap with the 7 bolt head.
I think its cheap insurance, reinforcement of the bottom end for such a conservative number is not a bad idea, remember.... u will just go up from there (horsepower)
It is not needed stock 6 bolts can hold alot of power but if it is some thing you want get it. As Fare as honing the mains it is probably not needed but I would install the main studs and girdle to check or have a machine shop check the mains for you.
