2G Kiggly 6-bolt crank trigger sensor
I just received an e-mail from Kiggly about this sensor to help with anyone who wants to use the sensor for their 6-bolt swap
The 6-bolt crank trigger uses the OEM 2g connector, so it is plug and play for a 6-bolt swap in a 2g without purchasing the extra wiring harness for the CAS. You will need to use your 2g cam sensor and OEM wiring. If you have the version with the cam sensor on the cam gear rather than the far end of the cam, you will have to get some portion of a wiring harness to use it with a 1g cylinder head. Personally, I prefer the 2g head in all applications so I would just recommend that.
  • Wanted 6 bolt NT water pipe
    • chrisman287
