Keyless entry wiring harness diagram
Ike66
59
Dec 4, 2006
apollo, Pennsylvania
Ok so im getting ready to install my keyless entry system (code alarm csi100)and instead of finding all the wires in the kickpanels and such i figured i should just be able to tap into most of the wires i need to at the harness that would have plugged into the stock keyless entry if it had been installed. There are 2 harnesses behind my driver side rear panel and im wandering if they would have both went to the keyless module or just one of them....also would the wire colors in the harness probably be different than the ones here: http://www.vfaq.com/mods/wiring-gen2wir.html and if not is there anywhere i can get a color guide for that harness? Thanks for any help.
ok so i started probing those harnesses with a multimeter and found that the colors seem to be matching up to the ones in that chart.....but for the lock and unlock wires they only seem to rest at like .2 volts ....while the dome light wire rests at like 12 volts ...is that normal?
