keep my afc..or sell it for an eprom flasher
Jeff_Ciesielski
107
Nov 6, 2005
Seattle, Washington
So here's my dilemma. I got a good deal on a pair of AWDs ( 1000 for both, WOOT! ) and im starting to budget things out for a mild ( ~275-300) build on one of them...my best friend gets the other one. The question is, do I sell my SAFC-II, which is currently in my rx7 and use the money to buy an eprom flasher and a new compressor wheel for my 16g, or should I buy an eprom flasher and keep the safc? I have no worries about being able to reflashing my eprom to reflect the setup i'll be running, i just want to know if it would be in any way beneficial to keep the afc.
thanks in advance -
jeff
if you are sending the ECU out to be flashed then keep the SAFC cause you will need it for small tweeks rather than the large compensation needed without the reflash.
  • Wanted 6 bolt NT water pipe
    • chrisman287
