just put in my 6 bolt have a few probs...please help!
Laguna739
138
Oct 8, 2002
Loveland, Colorado
I have a 95 talon. got a FFWD motor and lemme just say its sick.. this thing is BEAUTIFUL...LOL ok back to the point so i got the engine in and everything but it wont stay idling... i checked for boost leaks and had 2 one at turbo and one at throttle body i fixed them both so everything is tip top. i installed new NGKBPR6es gapped at .28 and used the wires you provided.. now heres the problem... to start it i have to have it floored... but after it starts it wont rev up and if i let off the gas it dies... started it at partial throttle and i have decent-amazing response but if i let off it immedieately dies. pulled the plugs and they are black so i know im running pig rich. timing is spot on and everything else is working great. could you give me some ideas on how to alleviate this snag.. mods needed to know so you can help are an S-AFC 2, B16g, 550's, 2g fuel rail and 2g throttle body (only untill i can get a 1g) but can you help with any suggestions on how to fix afc settings or anything will work im outta ideas oh and ps i dont have a FPR witha 255 lp fuel pump
please guys/gals help a guy out just tell me things to look at i can go from there im desperate!!
you don't have a fpr with a 255 pump???....uh you might want to do something about that like RIGHT NOW, could be the rich problem your having.............. :dsm:
ok guys it had thrown a cel last night and i just went and got a code puller the codes are:
P1400 - Auxilary emission controls
P0120 - TPS/pedal position sensor A Circut Malfuntion
i think the second one is whats causing it to not run but how do i fix it? also does anyone have a pic of a 2g throttle body with the vacuum lines just so i can make sure mine are right?
