Just got my head from the shop
GettinPaper
289
Aug 31, 2009
Battle Ground, Washington
I'm new to this stuff, so awhile back i blew my headgasket and found out
my cylinder head had bent valves, so i just got enough money to fix it and just
got it from the shop.. and it looks like this..
So i was wondering what to torque the camshaft bolts down too?
And another question do i have to align the marks on the cams?
How would i do that? just tighten the camshafts and move the cams?
if you put your engine at the middle of the stroke you can clear all the pistons while you rotate the camshafts into position. Then you can rotate the crank back to TDC.
