Just did a blt
The holes in the elbow can be welded or just mix up some JB Weld and patch them. Make sure you use zipties on the ends of all your vacuum lines to prevent leaks. TB shaft seals are very common places to leak, you can get new ones from JNZ, STM, or ExtremePsi and there is a VFAQ on how to change them.
Once you fix those leak, boost leak test it again, you probably have many more leaks.
Hope this helps!
