jm fab drag mani help
dsmreck
68
Jan 6, 2013
grand rapids, Minnesota
I have a 1g jm fab that was made for a q45. I re flanged it for a 1g and now I need to cut the throttle bracket. can someone give me exact measurements of what i need. also maybe taken from a few spots as it may need to move forward as well.
^ wow that was helpful, keep contributing pal.:notgood:
For anyone who wants to know this the 1g throttle bracket it 7/8 from the top of the plenum to the outside of the bracket. The holes are 5/8 from the top of the plenum.
take some measurements of the bracket on the cable. That will be your rough width, and length. Get an aluminum piece with those dimensions approximately 4-5MM thick. Choose a mounting location that is out of the way that is straight behind it (distance isn't critical as long as there is enough adjustment for the cable). Be careful not to put any strange angles in it, and make sure nothing will interfere. Then drill and tap holes for the bolts. Tig weld it on. Easy stuff.
