JDM swap in progress...quick question?
SwimShady
38
Feb 12, 2004
Marysville, Pennsylvania
ok guys, im swappin out my nt motor and puttin in a jdm. got my engine out, split it from the transaxle, the old one is 7 bolt, new one is 6 bolt :) so im glad about that...my quesiton is...the oil filter housing on the jdm is different? on my usdm motor there is a little sensor on the bottom...it resembles a wastegate but obviously its not, however, there isnt one on the jdm motor, its just the mount and then the oil filter. anyone know what this is or what it does? ill post pics tomorrow when i get them taken.
thanks
Good question. From the info you've supplied I would have to agree with the above post. Although you could easily swap the housings and utilize the sensor, [I realize an oil cooler(more time and money, but well worth it), would also be required]. An aftermarket guage will have to be used, but If your willing to search, you could easily find one (guage) for very cheap. Good luck.
Yes that would be your sending unit. You will not be able to hook your stock one up to it. I have a jdm motor in my car and my oil pressure gauge dont work, so i just got an aftermarket. It was something i was going to do anyways so it wasnt a big deal to me.
I have a new Autometer Sport Comp. Oil pressure gauge im lookin to get rid of b/c i dont need it. If you are the least interested just pm me.
Cody
Cody
post pics.:cool:
yeah Im having the same problem when I put in my jdm motor, on the oil filter housing I dont see a oil pressure sending unit. I was wondering though if I could just add on the stock oil pressure sending unit onto my oil filter housing or will that not work. Just in case it doesnt I already have a oil pressure gauge and I would think that would be the same spot the stock sending unit would be the aftermarket would go as well.
cool thanks for the help guys. i already tried to swap it like you said and it dont work...like you said. ill look into gettin an aftermarket.
Cody [/B]
post pics of the guage that your looking to get rid of. Anyone who's interested in it will most likely wanna see it. Thnx
Hi guys well I still cant find what port to put in the oil pressure sending unit on my oil filter housing. As you can see from the picture there isnt one on there. So which port would be the correct one to put the sending unit in?
