oldfart
- 0
- Jan 9, 2005
charlotte,
North Carolina
This may be an idiot question but it is also a technical question - on balance shaft removal - vfaq states that on the BS tensioner pully bolt hole - to use a shorter bolt and seal it - I had the idea of using JB Weld heavy on both sides of the cover instead of using a bolt..also roughing up the hole a bit with a file to aid it in sticking good.
Has anyone done this with success or failure in past
- is this a true idiot idea????
or ... don't quit your day job just yet.
. you have those parts at arms length without going anywhere .
