issues above 5 psi
brian102
142
Nov 6, 2010
coldwater, Michigan
Ok i was having a major misfire above 5psi of boost. Ended up being a bad wire on cylinder number two. Now my question is. I mise well upgrade my wires since im replacing them. Should i pay 50 from advance and get some 8.5mm wires or go ebay and pay 80 for a set of 10.2mm. Any benefits of going bigger?
Depends on brand, not all wires are made the same.
NGK wires are good wires to go with and are affordable. If you want something that is better, I would go with the 8.5mm MSD wires. They make a 10.5mm as well.
You will suffer some radio noise with the MSD wires since they have a low resistance compared to other wires.
Start at post #3
http://www.dsmtuners.com/forums/fre...3-answer-spark-plug-wires-ignition-wires.html
If its 8.5 good quality vs. 10.2 ebays, id go 8.5 just because like liquidx said they arent all the same
    • Sdcryan1
