ISC/IAC motor shopping. (Merged)
samvdb89
88
Mar 2, 2009
Rathdrum, Idaho
Where can i buy an isc from? found a few options but i'm wondering where
other people get theirs from..
Mine was making a funny clicking noise with the ignition on, so i pulled it off and tested it and in the middle of taking a video to put on here it completely stopped working..
Ok, Dsmgraveyard is out of stock, couldn't even find one on mitsubishigraveyard, the third link looks best.. but dang that's spendy.... also every ISC i've found has a connector right off the motor, when the one im replacing has about a foot of wires before the connector.. so i'd have to do some wire work..
any other places?
Are you sure you tested an ISC. I have never seen one with a harness.
This is the ISC I have... it has a harness..
The ISC was making this stuttering sound that was very irregular, pulled it, and it was still making the sound, was gonna make a video so you all could tell me what you guys thought of it, but as soon as i started the video it died and stopped making any noise at all, doesn't move anymore, used to move in a little..
wiring up a harness wouldn't be too hard, but is their an easy way to test if it's the motor or the signal coming to the motor? i'm not experienced at all with testing electrical.. so if there's a step by step link with pics and stuff floating around out there.. that'd be nice..
Anyone had experience with these ebay ones?
Eagle Talon 90-94 91 92 93 ISC IAC Idle Air Controller : eBay Motors (item 230421764549 end time Apr-08-10 09:48:02 PDT)
I don't want to steal his thread. But I want know is WILL 91-93 ISC work for my 90 GS-T. Cause a 90 isn't cheap. And a good one is hard to find
Ok. I got the plug from a 92 tsi and my pig tail from 90 ISC. How do I wire it up correctly.
This is the best way to use 91-93 ISC on your 90 DSM. You don't have to hack on your car or void the new ISC.:)
Here is a photoshop pic of how it should be wired up.:thumb: This will work. I tested it one two different car. My GS-T and Buddys Talon.
NOTE. My Female plug is different colors be it is from a Hyundi. I don't know if the colors are the same for the Talon, Laser or Eclipse.
What ISC's are compatible with 1g's out of the newer models, and do non turbo use the same ISC?
Like will a ISC from a 95 work?
2g N/T ISC's are different, as are the 1.8 ISC's. The 1g's have 2 different part numbers (changes over in mid-92), so I'm not sure of the difference. My guess is they both would work. There is also a 3rd part number for the '90 ISC.
All of the turbo models are compatible though. There are also some Galant ISC's that can be used.
Cool, i got a list of a few cars that have the same one off of one of those links..
but no matter what i do i'm gonna have some wiring work, because i have an early 1g..
Mitsubishi quoted over $400 for one, the best one online I've found is $132+s&h... :(
couldn't find the one on rock, i did check it out though.
just found it.. had to look under a 91 eclipse.. figures.. i just bought a used one for 45.
The guy for throttlebodys.com sells rebuilt isc's for $50 with a 90 day guarantee. He sells them on ebay, search under: Rebuilt 1991-1999 DSM Eclipse / Talon Idle Sensor (ISC)
