is this turbo any good
If you are running a 60-1 on a stock 2.0, it will lag alot for street use. An i say 2.0 because you dont have your parts listed. So for road racing, it is too slow of a spool for a short track. And for Drag it is great on the top end. But...if you where running this on a stroker motor, then you can do anything with it. Because the stroker would move the whole powerband to the left. so a big turbo with some lag on it will bring it back to the right. So it all depends on what you are gonna do with it, and whatcha got already :cool:
And to tell you...it sounds CRAZY when it hits full spool. And since it isnt a ball bearing, it comes all at once.
Without supporting mods it will lead to fuel cut. With fuel cut eliminated and no supporting mods it will lead to nuked pistons. Enjoy.
This turbo can be used for a dd easily. You dont show any mods in your profile. This turbo will need alot of supporting mods. Full exhuast, FMIC, clutch, fuel pump , injectors (850) Dsmlink/dsmchip. Unless you have all these mods than dont start thinking about throwing this turbo on your car.
I don't realy care about lag. My b16g blew up and i want to upgrade.
All I want to know is this turbo going to last me at least 2 years.
I am geting shep stage 3 trany and wan't to get my car in low 11's.
I own 05 EVO for dd
Check my profile for my mods I just updaded it
Sorry about my speling I am from bosnia and my enlish is not so good
I own 05 EVO for dd
Since this one kinda died...with your profile (thanks for updating it :thumb: ) You should be able to run this turbo. Just remember you will be entering lag city. It is a turbonetics turbo, and the propeller shaft is pretty weak. So 2 years only if you don't give it a serious beating everyday.
check into PTE 60-1 turbos, havent heard many good things about turbonetics. in the Va area anyways
My buddy has that one. It lags like hell as stated above the rpm for spool I second. After it spools it pulls like hell and is awesome. He had the turbo rebuilt because shaft play became excessive really fast. So far after the rebuild its still doing good but it has only been a year.
