Is this turbo any good at all?
Kevin TSI
136
Jan 11, 2007
Muncy, Pennsylvania
Ok i found a turbo online and the description goes as follows.
Is this way too big? I e-mailed the guy about more info about the turbo.
Here are a couple more i found.
Does anyone know if these second ones are considered a 50 trim, 57 trim or what. They all are hybrids so i am having trouble making sense of it all. When would i expect to hit full boost on any of these?
With the correct supporting mods nothing is too big. To some level of sanity. Do you have or will have the supporting mods? If not then it will not work. What are you looking to achieve? 300 horses,400 horses etc.? If you want to stay close to stock go with an evo 3 16g from slowboy racing or extreme psi or one of our other vendors. Good luck Travis
I'd like to make 350-400hp.
I am very interested in the second set of turbos I put up but do not know which of the 3 would be the best.
Fuel mods will not be a problem and I will be ready to upgrade my turbo. Right now I have a 16g.
I was thinking that the second turbo that is on the red plate would be the best for me. I believe its a 50 trim and I think it would spool quickly.
350-400whp on pump is real hard to get on the evo. I would go with a larger turbo for your goals. If you plan on running your 16g hard and race gas than you can get 350whp. But if you want more than 300whp on pump I would go with a larger turbo.
Would you recommend any of the ones above?
