Is this everything i need for a clutch install?
Dream On
2,242
23
Sep 6, 2003
Athens/Oxford, Ohio
I'm changing my clutch and flywheel out in a month or so, and I want to get all the parts together. Here's what I plan on getting:
Spec Stage 2 clutch kit
Fidanza Flywheel
longer flywheel bolts
clutch fork and pivot ball
Is there anything else I need to get? I should get the longer bolts and fork and ball correct? I've read that they should be replaced. Thanks.
The kit comes with this:
"Stage Two: High clamp pressure plate, segmented chatter-free Kevlar disc, bearings and tool."
So I'm assuming the alignment tool is with it, and there is a TOB with it as well. But I shouldn't use the aftermarket one and just go to the dealer? Any other suggestions? Thanks guys.
Just to be safe I would replace the clutch fork and fulcrum pivot ball. Over time the forks get bent and don't engage and disengage properly. RRE has some info on this as well as some others. You can get both parts for about $80. You might not need it but it beats doing a clutch job twice.
He already mentioned that in the original post.
Transmission fluid, and possibly Radiator fluid, And something to re-surface the flywheel with.
Something to resurface a brand new flywheel? I should be ok with the fidanza and this combo shouldn't I?
