is this a knockoff tial?
foxracing4500
336
9
Jan 21, 2012
Europe
pretty sure it is and wanna get some use out of it but where do I find springs? The spring it has in it now is set at 20 psi.
I just bought a Grey spring from extremepsi.com along with a gasket and vacuum line. I had this pressure tested at work and I cant believe it held 20 psi. Looking at all the springs on extreme to get 20psi you need to run 2 different springs. Anyways all should be good thank you guys.
Be careful buying random springs. My friend bought a 15# spring for his knock off and he ended up running 10#. Could work the other way and do some damage!
The spring ratings between Tial and the knock-off companies are usually all within a half psi or so, BUT... they change up the color codes. So you are correct....you need to make sure that you are running the spring you think you are. ;)
  • Wanted 6 bolt NT water pipe
    • chrisman287
