is nitous safe on my gst
CRAIG___
54
Apr 22, 2008
KING, North Carolina
ok i have 95 gst would a 50 shot be safe on my car would like it for turbo lag in the big turbo heres upgrades i gotta run for the night so will not be able to reply but please leave me ## opinions on whether im safe or should just leave it alone
front mount
fpr
walbro 255
type s bov
precision 50 trim turbo
3 inch exhaust
stock injectors
stock manifold
suppose to have h beam rods and weisco pistons(but would it be safe incase its stock )
mbc
forced performance intake
i just wanna know if a 50 shot would be safe with or without the rods and pistons its suppose to have or should i just leave it alone LOL give me ## opinions thanks alot be back tom. night :sneaky:
A wet shot should be fine but I can't believe you are still running stock injectors with those mods
First of all, please use some sort of grammar in your posts, it makes reading them much easier.
About running nitrous, you don't have enough fuel. You don't have enough injector for the turbo alone, let alone throwing nitrous in there. 50 trim is not a big turbo and doesn't require nitrous for spool up. At any rate, on your setup now, I wouldn't mess with it.
it was typo i tried to edit it but could'nt edit the title and its not a huge turbo but take off sucks spool not that fast after its rollin its good and im gettin rc 750 injectors was my plans right now im just repairin it from a incident with a deer at 45 :cry:
I think you should upgrade your injectors before you run nitous but why do you want nitrous do cams and lifters for more power , and a datalogger if you dont have on or dsmlink.
ok thanks will do ok out for the night thanks for all the help everyone very good sight answers very fast have a good night be back soon
I wasn't talking about the title, I was talking about your posts, they have no capitalization, punctuation, just grammar in general. Not trying to rag on ya, just saying it's easier for us to read, and help you out.:thumb:
I think if you get your injectors upgraded, you may be able to get away with a wet shot. Do you have a way of tuning it though? Or a wide band to keep track of things? I dunno, if it were me, I'd be leery of just slapping nitrous on without knowing what my engine is doing.
When your dragging, there isn't a time you'll be out of the RPM range where your 50 trim is spooled. Anyways, good luck.
deff step up to some 750s or something. I do not see how you are able to drive that without boost cut.
it used to hit boost cut or fuel cut whichever that is but after fuel pump install and regulator it went away im gonna hold off on nitrous until i get injectors dsm link and a tune thanks for everyones help
you could do a wet 50 shot probably with no issues but if you're going to spend 4-500 bucks on a nitrous kit, you may as well just buy dsmlink instead and make some real power out of your car safley and you will be way more satisfied, and with a good tune you shouldnt see much of any turbo lag from a 50 trim
i believe that is what im going to do thanks for the info and it lags a little in first taking off thats all but dsm link and a tune and i know ill be happy thanks
Nitrous is like a hot chick with STDs, you wanna hit it but you're afraid of the consequences...
Get DSMLINK before anything else. A good tune is much better than Nitrous.
And to reinforce it one more time...use good grammar and punctuations some people on this site will not take you seriously if you don't change it. :thumb:
Install a Window switch, fuel safety switch, don't spray above 1300psi, and run a wet shot, you should be fine.
Oh, and bottle warmers are a night and day difference.
