eboy0
- 641
- 4
- Jul 8, 2006
Chicago,
Illinois
Hello, first time poster long time searcher.
I've had this car for a little over 4 months now, been running up to my expectations(always had high idle). Until recently all of a sudden my idle went up from 1300 to 2000(once warmed up). Also, when i first start the car the idle is rediculosly bouncy, going from anywhere 1200 to 400 almost to a stall. Once the car is warmed up, it evens out anywhere from 1100 to 2000 but stops bouncing.
Had a compression test run on all 4 cylinders... almost 210 in each.
I put in new spark plugs: Bosch PLATINUM GAP=0.032"
The old ones were covered in so much carbon it was unbelievable.
I've calculated i'm getting about 9-10 mpg out of this car, so i'm guessing cat is clogged(getting that checked out monday) also may need new o2 sensor.
Does anyone have any idea whats going on with my car? Is the engine just dying? Is something else the culprit?
No check engine light has appeared yet, though the engine does shake ALOT.
If anyone has any info, that'd be great.
