Sotarts
- 1,953
- 24
- Sep 30, 2002
Chicago,
Illinois
After the car has been sitting undriven for a while (few hours, or overnight), after I start it, Check Engine, Radiator and Brake lights stay on for a while (dim) while the car idles. Power is being obviously drawn from the battery, since it stays at 12 volts. Basically, same symptoms of a dead alternator.
BUT, after the car has idled for 20, 30 seconds or a minute (lately), those lights completely shut off like nothing is wrong, car idles perfect, voltage goes up to normal 14+ and stays there for however long I drive, battery is being charged, etc... There are no drivability or any other issues otherwise whatsoever. If I don't drive the car for a while again, this happens again, every time. It's been happening for the past three weeks or so. Seems like it goes to normal function faster when weather is warmer.
ECU is fine. Does this with two different ECU's. There's no crazy wiring in my car. Everything else is peachy.
Is my alternator going out? Or some wire is loose/has dirty contacts and makes full contact after heating up???
Can someone WITH EXPERIENCE please reply? Thanks.
