caseclipsegst
- 54
- 0
- Nov 13, 2008
pearsall,
Texas
I know this topic is played out I've searched but please help lead me in the right direction .. Mods.. Rebuilt engine stock internals(2000miles on the clock)16g,Megan o2 housing,2.5 to 3" dp, 3" no name exhaust,gm maft with translator, Walbro 255.. No tuning at this time
I bought the car with a spun bearing so rebuilt the whole engine, ended up putting a 16g and all that and ever since I got her running I've had this problem of when I give it wot the guage will creep up to 20psi and do like a fuel cut type of jerk/bog and won't go no where till I let off the gas .. I have the mbc set to the lowest possible setting.. Mind you that this happens only when wot, now as long as I don't put the pedal down it'll run ok.. I did a boost leak test and found the bov to leak like crazy could this be the biggest cause? Or is it the dreadful 16g/ big exhaust(no cat) deal..
I've had this problem ever since the rebuild and it's time to get rid of it.. It's embarrassing when someone revs up to you and you have to take it ### they will smoke you in their minivan ha
