2G Is cold phantom knock normal?
bmxfelon420
652
62
Sep 6, 2005
Napoleon, Ohio
Hey just wanted to ask for some opinions on this behaviour i've been seeing. Basically, if I start the car up, go pull away and give it a bit of throttle before it's up to temp, I'll hit about 3 degrees of retard. This issue vanishes once the car has warmed up a bit. It will do it with no boost when cold as well, so this has me thinking that the issue is just piston slap. I have heard that forged pistons often make a bit of extra noise until they warm up. Does this sound normal? Like I mentioned, once the car warms up I dont have the issue.
If you have forged internals and depending on your P2W clearance it is possible to be piston slap as the metal will expand once warm. I would at least until engine temp gets up to 170* before moving as I don't want to risk any investment I have put into it.
If waiting to warm is too much, invest in a remote start system.
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
  • For sale ACT clutch 2600
    • Briant91
  • Wanted 2g 2g rolling shell
    • DSM_Thorpe
