IPT end clutch kit in... still problems
darkiller_666
477
Feb 19, 2008
Salina, Kansas
So I just got done installing my End clutches from IPT. I followed the video to the key and all is good, or so I thought. I do have OD now, which is great. The trans is slipping though, bad between gears. Sometimes getting stuck in first. If im going about 30-40 and floor it the trans jumps and burps like it doesn't know which gear to go in. Some times when coming to a stop the tires will lock up. I would rather not have OD then all these problems. The car was at-least driveable at city speeds before. I have no idea what is the problem. I double checked fluid level, warm with car in nuetral. Fluid is dead on. Its a mix of half brand new fluid, and half fluid with 200 miles on it with the old clutch kit in. The car had to completely worn down clutches and all the metal plates seemed to be warped. I replaced all seals...... Please if anyone has a clue, please help! PS no check engine lights are on either. Car is 100% stock!
Thanks so much!!!! The video was great! Made me confident i could do it and it was as easy as you make it look. Minus the damn snap ring...... I wish more vendors were as supportive of there product! I will for sure call you tomarrow!!!!
So what was the outcome? Did you figure it out or did you take it to a mechanic. Please finish this post. Much thanks.
