Intake hose is cracked...where can I get/make another?
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
My stock rubber intake hose between the throttle body and BOV is cracked. I want to keep it stock diameter for now. Where/how can I make another? Radiator hose maybe? I have no welding skills yet. Worried about getting a used one. I don't want someone elses problem.
Thanks
Edit: Meant to put this in the bolt on forum...either way I am just fine with it.
You can always just buy an aftermarket hard pipe, or have someone make one for you. You could use a radiator hose if you could find a section that would work.
Was considering it, but it looks like 1g hard pipes for the stock intercooler are hard to find...example:
ECLIPSE & TALON - Intercooler Kits & Intercooler Pipes - Punishment Racing
Seems like 2g stuff is the norm and the 1g stuff is the exception. Could have sworn I saw a thing or 2 on ebay, but ebay is blocked at work.
I remade my own upper ic piping with a piece of exhaust tubing and a radiator hose. Just go to napa and take your hose in and say you'd like a radiator hose that size, or piece a few together that would work. It wont be ideal, but until you can get on ebay or elsewhere to purchase a hardpipe kit it's your best bet. You should have a significantly easier time finding the hose since you have a 1g, it's a lot smaller.
