2G Instrument cluster doesn't work. Replacements?
brandons 95
95
Jan 13, 2006
deltona, Florida
Does anyone know where i can get the instrument panel for a 2g talon because my speedo, tach, and back lights do not work so I guess it will be easier to buy the whole thing
If none of the lights work, I would suspect a wiring or connection issue. It's doubtful all of your instrument lights would go out at the same time. Are your other dash lights working?
If you are 100% sure its a bulb issue, then it might be easier for you to just pick up some bulbs from a junkyard. They can be found in Talons, Eclipses, Sebrings, and Avengers.
That way you won't have to have your odometer reset to report accurate mileage when you replace the whole unit.
When I got my car I didn't realize somebody removed the bulb on the CEL. But since I put it back in, I don't have a CEL, so I guess it really doesn't bother me.
