Installing Walbro 255 + SAFC.
Spookcorleone
199
6
Mar 15, 2005
Frederick, Maryland
Hey I will be installing a Walbro 255 with SAFC soon, and I've never tuned a car or anything before. So to atleast get it "running" until I can start to learn, what should I do / I need help setting the SAFC... :p
Also I won't need afpr yet will I? The 255 should mainly push more value, not more pressure?
Thanks!
no, you will overrun your stock fpr with the 255. it will make tuning very hit and miss. as in, what happens on one run, might not be the same with the other based on various conditions, load, etc.
i believe rre and prostreet websites have general settings for safc's with various mod lists, you can start there. also im assuming you have some sort of logger to monitor your timing, rpm and o2 volts with correct?
