Installing SS oil feed line into Filter Housing, is this the right fitting.
Lordpaxin
1,890
15
Apr 21, 2003
Jackson County, West Virginia
like the title says
its a jdm oil to air cooler housing.
same as the 90 model right?
thats the correct one. You would want to heat it up around the bolt, and use a socket type allen key to break it loose.
that's where mine is at. You can see it behind my cooler lines. Check my gallery.
And it gets pressure...believe me. I forgot i took the line off at the turbo and started my car. It was raining oil all over my engine bay. :cry: It sucked
