installing a boost gauge
Its the rubber hose that goes to the intake to the fpr on the drivers side, look by your
fuel rail, and youll see it, just get a t- fitting and hook it up.
I used the FPR on the Firewall on the drivers side. There are little black hoses and I used the hose that is solid black. It allready had a piece in it that I simply removed and put the T pipe clamped that ran the boost line thru the firewall then up to the gauge.
Pretty easy -19-20 on idle -25psi on decel and reads perfect up thru the rev range.
