Installing 550cc injectors in a GS
TT_NS
203
Dec 2, 2003
I have an engine built for my eclipse gs and has 9:1 comp pistons and i was planning on running 150-200shot of nitrous and was going to put 550cc injectors on it. Do you guys think they will work or are they to much. also if i install those injectors will i have to use the resistor pack?
if you stay n/t they will be liek 90 times to big. 450cc is the absolute biggest id put on a n/t with 11:0:1 compression and ful head work done. 450 will work on a highly highly modded n/t
55- is to big and yes turbo injectors require a resistor pack to use in a n/t
different injector impedence
Would the stock injectors work with 9:1 comp pistons?
what stock injectors, turbo auto,non turbo, or turbo manual trands. all are different.
heres a breakdown
stock n/t injectors 240cc
stock turbo auto trans 390cc
stock turbo manual trans turbo car 450cc
non turbo fuel pump is also smaller. non turbo injectors are high impedence and turbo injectors are low impedence.
use search this is a very talked abotu topic
