Installed pistons/rods crank wont turn.
FastGS-T
295
8
Oct 20, 2005
Arab, Alabama
Ok crank spun freely and i installed the pistons and rods, now it wont turn.
The caps were not with their rod when i got them (used 1g Big Rods) but I am using new bearings and the crank is turned 10 under. So should it still matter the cap order? I know i can try and spin it after installing each rod till i find the problem but i want to make sure i know what to look for befor ei take it apart
the locks for the bearings touch the same side on the rod and cap correct?
also i dont have the bolt that goes into the crank to turn it, i was using a crescent wrench with it cought on that lip on the end to put the sprocket on correctly. Do i just need that bolt? I was turning pretty hard
edit: also when i un torqued the main caps the crank turned fine with the rods attatched.. was i just not turning it hard enough?
Plastigauge is your friend.:sneaky:
GO back through and check all of the clearances. It sounds like you have somthing binding.(to point out the obvious) If it turns when you loosen the mains I would go back and make sure yyou have the correct bearings, and mic everything. Better to take the time now and get it 100% than have to take it back out of the car. Good luck
Yeah man I used plastigauge, and everything was correct, I just went back and added more assembly lube, and turned the crank each time a torqued on a cap to make sure the caps were in the right place. Then once it was all torqued again i can turn it now :)
:thumb:
I rebuilt my 7 bolt and I checked everything twice. The first time it made about 400 miles and spun a main bearing. I took it back out and did everything again, it made it about 350 miles. Im going to a 6 bolt. I hope you have better luck than me. From the research I have done it has somthing to do with the main girdle, it has no way to positivly locate itself when reinstalled. I thought about putting the dowel kit in it but I just gave up. Good luck.
