Inspecting Engine...
seth98es
1,054
4
Oct 2, 2003
Keokuk, Iowa
Well I am going to go look at a JDM 6gvr4 4g63t that has yellow top injectors(510cc correct?) and supposedly a 16g. i am going to see if it is a 16g and check for shaft play, but what else should I check for? TIA.
Timing belt wear if possible(tension), pull the dipstick out and look at the oil for any milky white fluid, sign of a blown head gasket, check the basics if the motor is running, compression, oil leaks and other various important things. Yellow top injectors are 510cc.:thumb: Hope this helps.
