Injectors And Motor Break In
Status
Not open for further replies.
cristikal1783
Sep 13, 2003
Albuquerque, New Mexico
I have a few questions. I'm getting ready to put my newly rebuilt motor in. I have a set of yellow top 510cc injectors. Can i use these along with the 2g stock fpr or 1g fpr and the stock fuel pump. Another question i have is i got a set of 1g 450cc injectors too can i run these with the stock fuel pump, and the 2g fpr or do i half to use the 1g fpr to keep it at 37psi. Or should i put my new walbro 255 in and the aeromotive fpr and run the yellow tops or the 1g 450cc injectors. All i want to do is be able to drive it and just run stock boost. Any suggestions are greatly appreciated. thanks
Need more information; are you going to be running stock turbo, or bigger turbo and what boost levels are you shooting for?
Do you have any way to compensate for larger injectors? If not you need to use the 450's. If you have a 255 and a regulator you should install them. You should also get a datalogger.
Status
