Injector question
Chaosweaver
1,235
6
Mar 25, 2009
South Jersey, New Jersey
I've been running 550CC injectors on my daily driver for a while, I have it currently running a 20PSI spike un-tuned and nothing bad has yet happened, it seems to be running fine. Now this is where I come into a problem, lately its not getting enough fuel so its misfiring, I popped in the stock 450s and it runs well once more. I was wondering if 20PSI untuned on 450s is safe or if I run a high risk of putting a rod through the block. Its running a spike because of my exhaust, do I need to fix this (there's a space between the O2 housing and the downpipe that permits quite a bit of exhaust to leak through.)
Yes you want to fix that dont run more then 14psi on a stock fuel system how were you controling 550's?You just popped them in?If you did you need to get something to tune with and a widband and then watch your afr's and tune it.Dont run that much boost till you have supporting mods...
20 pounds of boost on pump gas with no tune... and then you "popped in" your stock injectors. I am surprised your car is still in one piece. Running that much boost, especially with stock intercooler would give grounds to some serious detonation. It will quickly destroy your engine, if haven't already. Turn down the boost to 14-15 psi and get a SAFC or DSMLink to tune it with. Trust me, DSMLink will be the best money you have ever spent on your car.
Im waiting for the "my engine is toast" thread.
There's plenty of info on here to get you started.
Research and mod safely, hack.
I'm running an Ebay FMI, a 16G turbo, 255 fuel pump and 264 cams on the Talon. I've spent more time on my 92 GSX than anything, tuning/mods have all gone in that car instead of the 2G, the Talon is just something I drive/race for fun. Hopefully the engine doesn't have much damage done to it. I'll try to get it a AFC neo from Ebay for cheap, if I cant find one I'll just get DSM link like I did with the GSX LOL.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
