Injector length
The only real difference is that s107's are 48mm long and the l107's are 74.8mm long, the s107's are also a 12.5 ohm high impedence injector where as the l107's are 12 ohm high impedence injector. As for which ones will work in place of your factory ones the long ones will fit the factory fuel rail. My question to you is how are you going to control such a large injector? because the stock ecu can't handle an injector that large. Mabe this can help you out on choosing an injector for your needs: http://www.2gnt.com/index.php?d=How to Choose Fuel Injectors.
I will have a MSnS wil a aeromotive 1:1 afpr. So go with the longer ones hey. I was looking a my injectors last night and they look pretty small like not even 2 inches long so u are positive of the longer ones fitting the stock fuel rail.
your best be is to measure your injectors and compare. The short one are just a hair short of being two inches long and the long ones are just about three inches long.
The import evolution one you mentioned is for turbo cars only...to my knowledge no one sells a fpr kit with braided ss lines for the n/t guys. You can always buy your aeromotive 1:1 fpr and all the AN fittings and ss lines and make it yourself.
