Injector duty cycle question
there should be a drop down menu on the main screen of pocket logger program, hit that and you should see a sub file named "preferences" you can change quite a few things like instead of pulse width read injdc, and you can make it to where all you have to do is tap anywhere on the screen to start/stop logging, its quite helpful.
hope this helps
teamitr said:
i'm using a logger from pocketlogger.com
but it does not log inj duty cylce is there any other way to check the duty cycle?
or can some one tell me about how much can i boost with 580 inj
http://www.injectorservices.com/FlowDataPix/s3102.jpg
this is the link for them.
Welcome to OBD-II. I have the same problem , you cant see injector Duty cycle, The OBD-I will actually let them keep closer tabs on there motor. I tried and tried to find a better program but its just not there.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
