Info on hex codes and tunerpro??
panamarojo
178
Sep 8, 2008
KLAMATH FALLS, Oregon
Where can I get info on more hex codes. All of the recommended sites I have seen while searching for this info. are down and dont work no more. I have most of the basics codes, but I need like knock sum, and just more info on the codes.
I have this site First Generation DSM EPROM Editing which is giving me a lot of info. The yahoo club has a wierd search engine.
Is there any sites that explain how to use TunerPro? Like under the rev limiter(rpm). Do I just enter a whole number? It says stock is 57.22 from the .bin I downloaded. Is there a list to explain this 57.22 number and MAF Scalar.
Any site out there that has recommended .bin for certain setups I could download? And recommended timing and fuel maps, octane tabe, ect...
dsmecu.com is back up btw. It is my site and everyone is welcome to join there, we have a pretty good group. Mods - if this is not appropriate let me know and I'll remove it. I was looking through the referrers to my site and saw this thread so I decided I'd reply.
To answer you actual question if you haven't figured it out your more then likely using a mismatched bin/xdf for example using a xdf modified for 2 step but using a Stock bin without the code changed
