incorrect throttle reading on AFCII?
gtrsrf10
Sep 14, 2002
When i first installed my afc everything, to my knowledge, was reading correct, now my throttle readings are off and when im on full throttle, the afc only reads 87%. Now this may seem like a dumb question but, is it possible that my afc is reading correct and theres something wrong with my TB or something along those lines?
What does it say when it is closed? Compare it to your logger. The afc should read 0 and the logger around 8-10%.
Both should read close to 100% when WOT. If the afc is off, you may have to reset it. If they're both off, you may have to adjust your TPS.
Only for a 1G. His 95 should read 0 at idle.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
