Im pretty sure this isnt normal
Bankles95GST
Oct 2, 2006
Beaverton, Oregon
I have an issue, I have a 2nd gen GST, Whenever i floor the gas pedal i get some mass hesitation, unless i let up on the pedal, at that point it goes just fine. First i assumed the worst, CW.....doesnt appear thats the issue, no prob with left turns. Maybe Turbo? Injectors??? Fuel line??? Any input is apprieciated
Don't always assume the worst. Hesitation is usually caused by the following:
1. Boost leak (run a proper leak test)
2. Old or incorrectly gapped spark plugs (use non-platinum only)
3. Failing spark plug wires
4. Clogged fuel filter
5. Clogged catalytic converter
If you have a logger, I would log a pull to see if there's anything happeniing with knock, but I would suspect simple symptoms first. We have tons of threads here on your topic. Do a search for hesitation and you'll bring up plenty of reference material. It would be helpful to know if the motor smokes at all when it hesitates, what color the smoke is, etc, etc. Here's a basic primer on boost leak testing:
http://www.vfaq.com/mods/ICtester.html
Keep us posted,
Andy
Thanks For the Info guys, i will have to go and check those things out first before i bug you awesome guys with anymore of my stupid questions
