highintenzity4
- 221
- 0
- Apr 30, 2004
Mission,
Texas
Thank you.
Gooberlog said:You have to block off the coolant feed or swap in a 1g n/t water pipe"not sure if it'd bolt up to a 2g.
are you refering to the water pipe or the turbo, or both, i know theres' no difference between mounting the turbo but i wasn't sure if the waterpipe from a 1gn/t bolts up to a 2g.TD05HTalon said:on a side note it will bolt up to a 2G just fine.
Accu-Sump is the biggest name, and the easiest if you don't understand the idea well enough to do your own.zross1 said:Another thing that is a good idea is an oil accumulator, not nearly as big an idea as it may seem like- just a tank that's sealed to atmosphere, orificed to the turbo bearing, and leaks down when the engine's shut off.
Do you have any links to this?? Sounds like a good idea.
