Ignition Fuse kees Blowing NEED HELP
LaN-
956
7
May 7, 2004
New Baltimore, Michigan
so i finally put everything back together ( re ringed my block) and i go to hook the battery up and it sparks real bad when i put the alternator positive on (square connection to the battery) so eventually i say Screw it and i'll just run it without the alternator i just wanna see the engine start. So i turn the key to ON and in about 3 seconds the Ignition fuse blows. I've disconnected everything i would of touched or taken off while i was working on the car and its still doin it. SO i have bad short somewhere but how do find it. I tried to trace back the wires for the ignition fuse but they go everwhere and there isnt a decent wiring diagram that i can follow. SO now here i am SOL and out of fuses, any ideas???
also is there an easier way to test it without blowing all of these fuses.
HELP!!
o yeah also, when i would unhook the alternator and hook the cable up to the alternator the horn would go on????
and sorry if it doesnt make alot of sense i got a killer head ache now from dealing with this. Honestly i just wanna get the car started and i'll take it to some shop and hvae them deal with it.
    • dsmmario
    • Canadian_CD9A
    • my98gsx
  • For sale 4G63 Six bolt cy head. Ported. SS O-rings. Ferrara valves.
    Six bolt cy head. Hand ported and flowed by Baker Cylinder heads. He started at Air Flow...
