Ignition crossing problems (I think)
2ndgenswapped
Feb 27, 2010
merrill, Oregon
Please help fellow dsm enthusiasts, my car does start, and run, but when I lift the hood I can hear a ticking sound that I think is my ignition crossing, and on my A/F guage at cruising speed (60 mph) it reads 10.0- 10.4, plus the car will not build boost until about five and a half thousand RPM (should be 13 but only getting 5 psi) and at that RPM the car will almost feel like the wrong cylinder is firing and the car violently shakes. My turbo is only a BR 16g.
I replaced the plugs, checked the wires and i think i have a wideband, but the car was woking better than it is now, i just got it running, and was having some trouble with the boost about mid range RPM (it was like the power would cut out then about 5 thousand RPM it jumped back to life) and the A/F ration was terrible but I was excited to have the car running, and i was showing it to a friend, I took him for a spin and when i got back I let the turbo timer turn the car off, and let it sit for about an hour, then when I left I got on the gas a little and no response from the turbo, and the A/F ration was worse than before, my car has yet to be tuned at all i just havent found anyone around my area that i trust with this car.
Intake Leak test , sounds like a massive boost leak to me.
Or plugs gapped horribly wrong.
You have an EMS ? if you are not sure about your wide band is it safe to assume you dont know anything about your EMS either ?
My apologies, the ems is not an ems it is actually an apexi s-afcII super airflow converter, and i dont know much about the car at all actually because i got it from my brother with all the current mods so im pretty sure it has a wide band but i dont know much about it. Anyways this morning i decided to drive the car to work and when i left the driveway it wouldnt go any faster than ten miles and hour, so i left it home and when i got ome from work i messed with the potentiometer (which is very touchy) and the car idled better:pray:, but when i took it for a test drive the car didnt go faster than twelve miles an hour, :mad:so i have decided to leave the car alone until i can get it tuned or fixed, any suggestions? The plugs are gapped at .030 instead of the suggested .032 i dropped it a bit on account of the boost being 13 PSI and the turbo timer is a Greddy full auto timer it stops at ten minutes cool down time.
