Ignalls replacement Bushings??
ApexVIII
812
5
Jan 12, 2008
Modesto, California
where can i get Ignalls replacement bushings? came with the Ignalls camber kit with the black base which is the -.75 to +1.25. the bushings are worn out so i bought another kit,
At the time i did not know that the ones on the car were the -.75 kit so i ordered the +1.25 to +3.00 kit and that is to much positive camber
so my question is where can i get a replacement for the bushings and i would like to get the poly ones not the rubber ones.
as you can see the kits are different so i cant pull the bushings off the new kit and put it on the old kit
the kit that came on my car
the kit that i ordered
Thanks alot guys!
well i think i read some where that places do sell the Poly inserts but not the rubber ones for the kit i am looking for. but no where lists it you have to call and ask for them
so tomorrow ima call ExtremePSI and see if they sell them
ok i called extremePSI and they said they are special order and can take 2+ weeks
FYI the part number is 35701 for the poly replacement bushings i found them at horsepowerfreaks.com for about $36 shipped for both sides. i will update when i receive them and make sure they are the right ones.
ok i got them in today and they do work for the Poly replacements the part number is
Ingalls 35701 for the black poly replacement
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
