@TDC
- 455
- 13
- Sep 10, 2012
Nor-Cal,
California
Hey guys! I've been searching the whole forum for the answer to my question. I've even tried the idle surge FAQ's. I don't know what causes this particular type of idle surge. My guessing is some kind of vacuum leak. Basically what happens is ill be driving my car (1g Talon Turbo) and whenever I put the car in neutral the idle will surge from 1000 to about 1400. Then when I come to a stop it will balance out between 900-1000 and not surge. So what could be causing this??? I am going to boost leak test it sometime this upcoming week.
, ill fix it tomorrow. A temporary fix is to unplug the sensor that I described above. Be prepared to backfire on decel though, and depending on how bad your leaks are, your idle could spike a ton. If it spikes too much, just leave it plugged in and fix your leaks. You probably have the same leaks I had. Check the lower injector seals and TB shaft seals. Depending on your boost levels and if you're using a paper intake manifold gasket, you might have blown it. I'm going to have to replace mine.
