"Idle" surge only while coasting
kthackst
410
10
Oct 1, 2008
York, Pennsylvania
Ok I have a 2g with DSMLink. All these issues started after switching to DSMLink. When I am coasting I have horrible RPM surge going on.
It only happens when the car is warmed up and I am coasting.
It will go from 1200 RPMs quickly to 1800 RPMs and drop back to 1200 and repeat but only when coasting. The moment I come to a complete stop then it will eventually settle down to 950 RPMs. I checked for boost leaks and found nothing. Attached are the logs. The log shows RPMs creep up it hit about 1800 RPMs then kick into open loop for a split second shut off the injectors then drop back into closed loop. Repeat until I come to a stop.
Any ideas? Thanks in advance.
I don't know how to read logs (program-wise), but does your O₂ signal cycle when this is acting up?
It should bounce between the lowest and highest voltages a few times per second. Are there any settings in DSMLink to ignore O₂ readings to determine idle mixture during coasting?
