Idle surge!!! & Idle fp w/ 550cc's?
clipsit
368
Apr 13, 2005
Tacoma, Washington
Hey guys...I possibly have a problem with my idle fp. I talked to the place that tuned my car. They said they left IFP at like 40+ psi!!!OMG I have RC 550 low impedance injectors and I believe I read somewhere on the forum where my IFP should be somewhere between 12-18 psi, and that was w/ 450's? Correct me if I am wrong, but I was told that IFP should not go below about 20 psi? If anyone could help that would be much appreciated? I changed my IAC valve b/c I had a CEL code that said the system was bad. I have to put one screw back on later today, so I will let everyone know if that does the trick, b/c it is surging from 1000-2000 consistently, still. If this does the trick then good, but if not, could someone still please educated me on what my IFP should be w/ 550's? Thanks.
holy crap 550s
with that huge of injector start around 15psi
what are you using for engine manamement
i am going to wager a SAFC
i read a few posts when i was considering that route that the SAFC is only good up until 440cc injectors
If you went to the megasquirt those would be no problem and you could use the oem fuel pressure
the easiest way to get the correct pressure is to get a pocketlogger or wideband AF meter and check your air fuel ratio at idle once everything is warmed up.
your should be running 14.5:1 on a wideband or if you are using a pocketlogger your short term fuel trims should be as close to zero as possible
yeah, the SAFC can only adjust +/- 50%...so maybe they couldn't tune it correctly with those big injectors
I've seen the SAFC handle that, however I just realized you said you have low impedance 550cc injectors.....if that is the case, mabe you should have someone check your resistor box. That could be a big deal.
sounds like vacuum leak
test your IAC with a volt meter to make sure it has the correct resistance
build a boost leak tester or start spraying carb cleaner around the engine
to find it
oh yeah and low impedence
NT ecu's must have high impedience or it will burn out the ecu
So I need a resistor pack then...right? The injectors are RC-PL8-550, meaning they are low impedance/low resistance, being 2.5-3 ohms and 43PSIg. They are also Peak and Hold. I hope this helps anyone help me.
not good...as said, we run high impedance saturated injectors...thus the need for a resistor pack to increase the resistance when using peak and hold injectors such as the 4g63 450's.
Thanks baxsom...I might try that, but for now I got the 550's in, so I got to make do. Thanks guys. As far as a resistor pack goes, would I just need one or one for each injector? Thanks.
yes one for each injector
check each one with a ohm meter before you start the car
resistance should be 12-15 ohms
also remember that the safc for the NT eclipse can only take away fuel so it is maxed out on the negative side and you are still running rich
you are either going to have to lower the fp even more or go to the small injectors
