Idle problems
clean96GST
462
Jul 14, 2008
Arlington, Washington
Ok so my 96 GS-T idles really low when its warmed up or hot, and really really high when its cold. What could it be? Also my thermostat on my dash doesn't work (don't know why) could that do something?
The missfire 2 cel is common it just kinda goes away, Well you see your thermostat sensor is linked to your IAT sensor so i would start with those two things first also check for any vac leaks. If your IAT sensor is going bad it will cause it, disconnect it and see if the idle, high OR low stays the same rpm without more them 150 rpm difference.
Intake Air Temp sensor. If you have a multi meter you can test the Ohms for it. Start your car and let it warm up, After that put your multimeter on Ohms and test the resistance on the sensor. It should be between .30-.45 ohms. If it is way under or over then there is your problem. Also take it out and look at the little dongle inside and make sure its still even there.
Dude what the hell one thing at a time my friend, I believe this person is new to DSM's bro. We need to help him not overwhelm him.
If you want to walk him through the list, carry on.
OP: the common reasons for your symptoms are listed in the link I posted. If you get stuck on any step post your questions. There's another link in the idle diagnostics post that goes into even more detail.
He said it changes during temps, I.E IAT sensor
I could also be the FAIV or a bad coolant temp sensor. The temp gauge is not functioning. That would be the first problem to fix. It's on the list.
  • Wanted 6 bolt NT water pipe
    • chrisman287
