idle problems
eclipsemodder
31
Aug 7, 2006
weston, West Virginia
Hello my name is james and i have a problem here it is i have a 99 eclipse gs i just put a motor together and put it in it ran good for a while but now it will fire up but if u dont give it any gas it will die and if i hold the gas down it will only rev up to 4000 rpms and then bounces between 3 and 4 and if i let off the gas it will die i have cleaned the egr valve intake and throttle body but it still does this please help me thanks James :dsm:
Firing problem maybe? I suppose you are using the stock ECU to run the car right? Check your timing, it really sounds like the car needs a tune.
If you're getting fuel and spark, I would try swapping the ECU with a known working unit. You might also want to verify that the firing order is correct and that the MAF isn't unplugged for some crazy reason. I think we've all done that a few times.
Keep us posted,
Andy
ok update i pecked on the cps and it will start and rev to 7grand but if u let it drop below 4 grand it wont rev up past 4 turn it off and start it again and same thing rev to 7 again and my cel is trippin a code now also is there a way to test the cps i backprobed it and voltage was fine
ok here it is i think its the crankshaft pos sensor i had a loose signal wire fixed it so now its throwin codes im gonna go hook it up tomarrow
well i hooked it up to a odb 2 and it didnt read any codes so i dont know what to do now trial and error i guess
problem solved it was the map sensor runs great now
Good job in fixing it yourself and sticking with it instead of giving up.
I love happy endings!
Keep us posted,
Andy
hehe we don't have a MAF sensor on the 420a. easy mistake for a 4g63 owner just a heads up bro.
Aww man, there goes my reputation! I actually used to have a GS, but I never really paid attention to that stuff back then.
Thanks for setting me straight,
Andy
