Idle is funny when cold, but is otherwise normal
JwUoNoG
528
3
Aug 12, 2004
Perry Hall/Parkville, Maryland
When I start my car up, the idle is very low, and it stalls. I adjusted my BISS to increase the idle speed, but eventually, the car still drops down, and shuts off. For example, last night I went to start the car, the idle was about 500. I adjusted it to about 800. I got back in, every 10 seconds or so, the idle would drop about 50 rpm, until it eventually shut off. I turned it back on, the idle is "normal", which in my case, is surging(1200-1500), or at 2000 rpm.
What is it that's causing my idle to die when I first start it up?
The first thing I would do is check your ISC coil resistances. It also might be a dirty throttle body or vacuum leak.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
