2G IAC sensor
mav4
Feb 3, 2015
Palamós, Europe
Hello lads,
It's been a long since I haven't post anything on this fórum, due to work and stuff. Sorry about that, because that's the only trusty dsm fórum I have found in the whole web.
Right now I drive a Nissan 350Z daily, but I own a '96 Mitsubishi Eclipse 2G GS NA with 4G63 (european) engine that I'd like to repair and conserve.
Months ago, I made a post where I explained that I have an acceleration cut from 3000 RPM to 3500 RPM with the engine beeing cold. As the engine gets warm, the acceleration cut rises at 4000-4500 RPM, even 5000-5500 RPM.
Well, I didn't solve the problem. I changed my MAF but it remained the same.
Right now, I've taken out my throttle body and I spotted an extremely burned IAC:
https://i58.servimg.com/u/f58/19/64/87/71/img_2010.jpg
I want to change my IAC valve, my Throttle position sensor and my Thermal sensor as well.
The problem I'm facing is that I can't find any similar IAC valve as mine. I just found those kind of valves:
https://i58.servimg.com/u/f58/19/64/87/71/767_ul10.jpg
I found those kind of valves from rockauto and similar shops, but I don't know If they are made for my car or not, as most American DSM wear the 420a Engine, and rockauto warns me that all their pieces are made for American cars.
Could you give me a hand about it? Does the GST valve fit in my car too?
Thank you in advance.
Is your IAC 4 pin or 6 pin or is it completely different? The 4 pin models look like they have a metal pintle where the turbo 6 pin units have a composite pintle. I would go with the one with the correct pins, do you happen to have a picture....its worth a thousand words so if you can, post up one of your IAC. :thumb:
MD614368
It is available on RockAuto also, but not OEM Mitsubishi.
MD614368
I've ordered a few from here. Never a problem. You def want the black top. In case you don't know by now, the black top IAC was on later dsms and all 3sis.
http://m.ebay.com/itm/Mitsubishi-30...th-MD628053-/162389703695?nav=WATCHING_ACTIVE
Thanks a lot guys. I ended up ordering the one from ebay. That's way i was asking for a part number. The one from ebay for example has another part number but i think it will work. I had hard time to find what i need and be sure is the right part becauae of this thing with to many models and part numbers :)
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
