2G I think my crank timing is off?
eddyspaghetti
121
17
Mar 27, 2016
san francisco, California
Hello, I drive a 1997 Mitsubishi eclipse GSX 7 bolt engine, my cams timing is correct but I wanted to know if my crank time mark is off? I manually cranked the engine 6 times before I took the timing belt off and this is where I ended up. what should I do next if its off? The timing belt is off right now, and since this is my first time doing this job, im not sure how to go about this. Im terrified of bending the valves.
Am I ok to taking off the cam lock and cranking the engine again with the timing belt off? ? Or do I need to install and tighten the timing belt THEN manually crank the engine?
If so how many more times? Any help would be much appreciated thank you
Its hard to look at it that way. My suggestion is as follows. Crank is the important part. Everything is always relative to the crank. Take the tool out, rotate until the crank mark lines up, THEN look at cams. To answer yiur question, yes your timing is off
But wouldn't that bend my valves? My timing belt is not on
  • For sale 4G63 Sheet Metal Intake Manifold
    Sheet Metal Intake Manifold for 1G Cylinder Head $300 + shipping and paypal fees* for use with...
  • For sale 1g 1G Leather Steering Wheel
    1G Leather Steering Wheel $70 + shipping and paypal fees* I know a lot of guys cut the 1G hubs...
  • For sale 4G63 Aeromotive Fuel Pressure Regulator
    Aeromotive Fuel Pressure Regulator $85 + shipping and PayPal fees* I would eventually replace...
  • For sale 2g 2GB Eclipse Reverse Lights & Bulb Sockets
    2GB Eclipse Reverse Lights & Bulb Sockets $35 + shipping and PayPal feesYou must be registered...
  • For sale 1992 Mitsubishi Eclipse GSX
    Stock AWD Turbo 5-speed 122,000 mi
    • bab96a
