I think it's broke... intercooler
stratt134
132
Apr 9, 2006
Houston, Texas
Check out these pictures. Wasn't me I promise, LOL. Is boost leaking out here? The car runs pretty good, the stock boost gauge almost hits the plus sign on WOT. Everything is stock except intake.
Thanks,
Sean
No... there shouldn't be any boost leaks. That's just the bottom plate that's torn, not one of the extruded tubes that air goes through.
My thoughts also. Hopefully the tube nearest to that hole isn't damaged also. How did that happen, out of curiosity?
Exactly. :D
If you don't want to/can't upgrade, I have my FMIC on (actually... it's been on for the last 8 months) and once I get pipes for it, I won't need my stock SMIC. If you still need one by then (and at the rate I'm going, it'll be another 8 months :cry: ) let me know and I'll give it to you or something.
One of the first mods I want to do is a FMIC so this just gives me a reason to do it sooner... I don't mind LOL
What's the easiest way to do the boost leak test?
